Harrisburger
- Jul 3, 2012
- Automatic
Hey guys, so I have a 1997 4.0 that is occasionally throwing a P1744 Torque Converter Stuck in Off Position code. The symptoms are: typically before the code is thrown, it starts shifting really hard in the 1->2 and 2->1 shifts (torque converter engages roughly?) and later the torque converter will decouple- but only in high gear. It seems to behave normally in the other gears, as I don't lose any of the lower gears. This problem typically only surfaces on longer drives of 30 minutes to a couple hours, but it can occur any time, even on short trips once it starts doing it consistently. Then it goes away again for a couple hundred miles like nothing ever happened.
Took it to Cottman a couple weeks ago, but of course it didn't do it while they were driving it- service tech even took it home for the night to his house about 30 miles away with no results. So, while I gratefully applaud Cottman for their honesty, I still have a problem. Kind of hoping I can fix it myself rather than paying as much as the truck is worth to get the transmission replaced. (even though the new tranny will be fully remanufactured and have a 50000 mile warranty... really tempting).
Any ideas of stuff to test or what to try? Thanks!
