Deluxedave
87 Ranger 2.9 4x4 - removed the transmission (FM145? - can't recall exactly what the info plate said) to replace the clutch. My first time reinstalling a transmission and I get the feeling something is not right. I replaced the pilot bearing in the flywheel, installed the new clutch using the alignment tool.
When I went to line up the tranny, I tried for a couple of hours to get it to slide in and the closest I could get was about 3/4 in of gap at the bell housing mating surface. I finally started a couple of bolts to pull the tranny in and it went very smooth and seemed to seat.
I tried to rotate the output shaft to the xfer case and it still rotates, but I would think that the shaft would not rotate if the splines were correctly engaged. Help!
