I have been working on the transmission for a 99 ranger, 3.0, 2wd and have not had any luck. The problem is that i only have reverse (absolutely no forward gears). I have replaced seals and gaskets, the torque converter, clutches and steels, the valve body, wiring harness, speed sensor, and solenoids, and still no luck. After reinstalling the 4r44e i still had ni forward gears, and after tearing doiwn the teanny again, the forward drum is burnt
