transmission identification
LittleHorse
Pryor, OK
not on an RBV, but at least it's a Ford.
A coworker of mine just bought an '81 F-250 4x4 with a 400 big block...the engine is not doing real well so he's thinking of swapping in a working fuel injected 300 straight six from a '95 F-150 that he already has sitting around. We're trying to figure out if there is a bellhousing that will mate this transmission to the 300.
Obviously, knowing what kind of transmission it is would be helpful...
Well, the 300 has the small block/351W bolt pattern, while I beleive the 400 shares the big block 351C bolt pattern....
I would do some research and see if you can find out for sure.
that's what I've found so far. Now I'm trying to figure out if the same transmission was ever used with a small block pattern engine, so we would know whether the proper bellhousing exists, and what it needs to come from.
Auto or Manual?
My guess is it'll be either a T18/19 or a NP435, both of which I'm pretty sure can use the SB bellhousing. Most have casting numbers on the side of 'em. I'd crawl under there and take a looksy.
The 351C used the small block pattern like a windsor or a 4.9.
the 351M/400 uses the same bellpattern as the 385-series engine (370/429/460) as a bit of engine trivia the 385 engine series gets
it's name from the 3.85" stroke.
so a 429/460 would bolt right up to that bellhousing, but to use
a 4.9 or 351W would require another bellhousing.
AD
351M, that's what I meant, sorry!
Allan, you are just full of so much useful info!
Good to see your back active on the forum these past weeks, have you gotten a new computer yet? One running at least XP I hope....
what caused all my problems were a combination of fratricide between a couple of faulty power supplies, a bad solder joint on my P3-550 mother board and a bunch of leaky caps.
My first three attempts to get up again resulted in further crashes
My desire to upgrade from win98 to Win2K aggrevated the situation.
because when I had the first computer "up" I formatted my new drives
NTFS and installed all my important data on them. and during a fallback attempt I discovered that win98 can't "see" NTFS drives... Oops...
But my computer was basically incapable of defragging drives that large that were formatted FAT32... Oops....
What I'm running now is a P4-2.4 and Win2k-SP4
I've got a 160Gb, Two 80Gb, a 60Gb, a 40gb and two 15gb drives
I've got my operating system on one of the 15gb drives and the other
is a drive that crashed several times when used for my boot drive
I now use it as a "Scratch pad" drive for freshly ripped audio
I make my mp3s, do my tagging, then defrag the individual files before transfering the files to my actual storage drives.
the 60gb is purely for audio playback, I use it for nothing else.
All my data is redundantly stored.
I NEED XP to run some of the applications I want
but I'm wanting to d that with a sealed registered copy of XP
and a fairly fast Core2 Duo board (don't need a quad and can't afford one anyway)
If I had a powersupply for the laptop I was given (a Gateway M350WVN)
and a 320gb IDE laptop drive... I'd have an XP machine up and running
I depend on the charity of the various "Early adopters" I know for hand me down computer parts.... hell the MoBo I'm running was a hand me down and the processor one I got out of a computer I found in the back of a Dodge Mini-Van in the junkyard.
My 60gb HDD came out of the same junk computer
but my 160gb I bought NEW last november just before
everything started dropping dead.
I'm poor and not particularly proud so if you've got any obsolete computer parts
I promise to "Love'em and Hug'em and Name'em George".
What I need is not some serious gamer's last computer, but the one before that...
BTW, LittleHorse, where in OK are you? anywhere near Norman or OK City?
Have any interest in a 1973 Carb 460engine?
AD
