LowStandard
- Mar 29, 2010
so i started tearing into the truck yesterday to do the clutch...got all the way to the point i was about to drop the crossmember and lower the transmission...and the friggin bolts are seized. i can get the nuts off and i can even get them to spin in the hole...but i can't get them to come out to save my life. i'm guessing there's a metal sleeve in the center of the bushing that is seized to the bolt. i know this is a relatively common problem...how have you guys dealt with it? cut the bolt and replace? or is there another trick?
