JP02XLT
Just thought I would let you guys know about an issue I fixed on a friends truck, (03 Ex-cab, Lowered 2-4, automatic), yesterday. It started out that he jacked up the truck to rotate the tires, he raised the front end of the truck by jacking up on the transmission cross member then put stands on the frame rails, then picked up the rear under the carrier on the axle. After rotating the tires he had a noticeable thump, he said it sounded like exhaust rub ect. He brought it over we put it on the lift & what was rubbing was the driveshaft on the tunnel. The trans crossmember actually bent upwards, into the tunnel. He had no problems prior to rotating the tires so we finally figured out that the jacking of the truck by the trans crossmember was what caused this. We took out the crossmember straightened it & then re-inforced it by welding in some 2 x 2 box tubing. The factory crossmeber was soft as butter, I could not believe how easy it bent. Any how just thought I would put this out there as a warning for other owners
DO NOT JACK UP YOUR TRUCK BY THE TRANSMISSION CROSSMEMBER. They bend very easily
JP02XLT
JP02XLT
