Transmission cooler line replacement
grunt58
Any good tutorials on replacing the transmission cooler lines? I've searched and don't see any tutorials or videos. I want to replace the whole line and not cut out the bad section. I'm unsure on getting access to the fittings on the trans. I don't think I can fit my hand up in there and wrench on them. I think I need to drop the trans which I've never done so not sure exactly what to do. Do I just need to unbolt the cross member and lower the trans with a jack? Its 4x4 do I need to lower the transfer case too?
2005 4.0L 4X4 Extended Cab
