JoeDaddy21
- Apr 4, 2020
- Age
- 25
- Virginia
- 2.8 V6
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 205/70r14
Hello all,
Recently I have experienced a new chattering when engaging the clutch. The truck is a 2WD ‘85 with 2.8 engine and TK5 trans. When I first heard it, initial thought was throw out bearing. Since I had the trans dropped I went ahead and put new clutch, flywheel, pressure plate, pilot bearing, and CSC with bearing. Got everything hooked back up, changed the fluid, and it still chatters. It only does it when I’m already moving or when decelerating in gear, so it doesn’t when starting in first.
Any help would be greatly appreciated. I’m at a dead end.
(also, here is a picture of the “Danger Ranger” as my friends like to call it)
