transfercase fluid
kenwheeler
Harrisburg, PA
what type of fluid goes into the 1350 transfer case? I keep reading about dex merc 3, dex merc 5 ATF. I just need to know what type I should get. I use 80/90 for the FM145 trans, will 80/90 work in the transfer case?
Do not use 80/90 in this transfer case! Ford says Mercon (not Mercon V), so any Dex/Merc ATF will be fine.
Mercon or Mercon V will be fine.
