Transfer case swap
WNY964x4
ASE Master Certified
Firefighter
ASE Certified Tech
East Pembroke , NY
i want to put a manual transfer case in my truck , and i have a couple questions
1. Will a manual T-Case off of a M5OD bolt up to a 4R44E
2. Will i have to cut a hole in my floorboard to install it
my truck is a 2000
Does your specific 4R44E have the mounting pillars for the shifter on the extension housing of the trans? some do not.
No you will not need to cut a hole in the floor, there is a removeable plate in the floor through which BOTH a manual trans shifter and a manual T-case shifter are meant to
go.
THE issue you are likely to encounter is compatibility with the front t-case output.
Your 2000 truck uses a six bolt round flange that couples to a Rezeppa type CV joint.
Most manual 13-54 T-cases will have a "half moon" flange that mates to a Double cardan type CV joint.
However most people who seriously wheel 1998-up Rangers have nothing good
to say about the Rezeppa type CV and there is another way.
The half moon yoke 13-54 T-case from a 1990-up Ranger explorer
will work perfectly with the front driveshaft from a 1995-96 Explorer.
thses use the SLA-torsion bar front suspension yet still used a half moon
yoke and a Double-Cardan CV at the T-case end of the front driveshaft.
Locate one of those driveshafts and you are good to go.
Does that answer all your questions?
AD
