Transfer Case swap?
Kingoverace
Solid Axle Swap
Jersey
I just pulled the 3.0 and trans out of my 98 Ranger Auto. I just put in the 4.0 and trans. It seems the trans shaft will not work with the 3.0 transfer case.
I believe the trans and motor 4.o to be out of a 97 Exploder. I have the transfer case from the Xploder, its nbd, just wondering if anyone knew for sure it was different size?
Also for my SAS. I have a 78 Bronco D44. will the stock UJoints bolt right in?
I know i saw the size camparisons somewhere but dont remember where.
Any help would help me get my truck back on the dirt. Thanks guys
It should fit fine. Both transmissions use the same size and spline output shaft. As a matter of fact all 4x4 Ranger transmissions use the same size and spline output shaft from 83+.
It should bolt right up, i just put a case from a 96 4.0 case in my 99 ranger with a 3.0 and it bolted up just fine.
keep the drive shaft out of the 78 and the one out of the ranger and put them together to make one. Thats what I did anyways.
and thats holding??
I've heard of people welding driveshafts together before but was't sure of durability. I plan on running a locker someday up front.
I took the yoke that goes to the axle and the slip yoke that goes the the t-case Cut and re-tubed the hole thing. Custom made drive shaft. did the same for the rear. fortunately I have access to a lathe. So far ist done me justice but its only bean about 3 months since I did the swap.
this is the rear I don't have a pic of the front but same Idea.
