texas03042
- Jun 30, 2013
- Automatic
95 ranger 2.3 automatic
I have removed the trans and put one from a 96 in.
but when I tried to rotate the motor to put the converter/flywheel nuts on, the motor is locked up. can't turn it with the same 16 inch ratchet the I used when removing the nuts.
if I loosen the bell housing to block bolts the motor turns.
what have I done wrong?
