Trans Problem...
94RangerMike
SC
Auto Trans Shift Problem
I have a 96 Ranger Super Cab with a 4.0L and auto trans...4R55E...160xxx miles. I bought it used but I doubt they ever did anything other than change the oil...
Now, whenever I shift from Park to any gear, there are a few moments before trans will engage. It really freaks me out because when I shift into Reverse at home, parked on a hill, the truck jumps when the trans engages.
Today, I was getting ready to leave the house and as the trans engaged the engine died and the O/D OFF light stated blinking...I was able to roll onto level ground restart the truck and was able to shift fine...
Went to local auto parts store that does free OBD testing and apparently I have EGR and O2 sensor problems out the arse.
Any ideas?
So, as I can see, it's normal for an electric A4LD to do all sorts of amazing @#$*%# things. Thanks guys!:shok:
takes a while for the transmission to engage.
I have a similar problem on my 92 4.0 AOD. Sometimes it takes a while for the transmission to engage. I have to rev it a little then it will engage. Any one have any ideas on the cause
yours sounds like the vaccuum modulator, cheap and easy fix
