trans interchange?
jarfly
got a 97 4.0 auto with i assume, a 4r55e, got a 94 4.0 parts truck, will the 94 trans interchange with the 97?
I am pretty sure the 97 4.0l has the 5R55E 5 speed electronic auto bolted to the 4.0l. I think that was the auto choice for the 4.0 and no 4 speed was a choice in 97.
Yes, most likely a 5R55E, but to answer the question, NO.
1994 Ranger will have A4LD automatic, your 1997 computer couldn't control it
Well it could be made to work with the addition of a TV cable, some vacuum lines, etc. And as long as you are ok with a check engine light or OD off light, and only 3 gears with no TC lockup.
The first three gears of the A4LD weren't achieve electronically, so they would still work.
could just swap a manual ecu from the junkyard to elimate those....
http://www.palaceofkibble.com/A4LD_Swap_Pics.htm
shows how to setup the torque converter lockup so its automatic, and you can swap in a earlier a4ld valve body(or maybe wire a switch) to get the 4th gear(or overdrive gear) .
if you wire a switch to the torque converter you and you forget to unlock it when coming to a stop it will stall the engine...
also i cant remember is there a length difference between the 2? if so you might have to modify the driveshafts(i honestly cant remember)
I believe all the Bordeaux transmissions, so A4LD, 4R and 5R series are all the same length.
