trans bolts
iceman2114
minnesota
how many bolts hold the bellhousing to the engine on 1990 ranger 2.9l v6 4x4?
The ones you can't see are 2 on each side and 2 on the very top.The best way to get to them is take out the cross brace for the tranny when it hangs down go over the top with a bunch of extensions and maybe a wobbly.Put a jack under the front of the motor if you need to.
I always get the two at the very top out from the top with a 13mm box end wrench. just reach back there and unbolt away. you can get the two middle ones too.
