trans and transfercase help
PaleBlue90
Solid Axle Swap
RBV's on Boost
Aurora Colorado
so my truggy is a 2.3 5speed, 2wd. i did a SAS on it. i have a exploder 5speed and eletronic case. i found out that the 2.3 and the 4.0 trannys are the same but the bellhouseings. is it possible to swap the tailshaft,and guts from the 4.0 to the 2.3 trans?
my other question. i will be selling,tradeing or whatever to get a manual shift BW1350. now my question. i will only be running 33's for now. shoule i get the BW1350 and a Klune5 underdrive or get a atlas? i can swing the price for one or the other.
with the atlas i have to run custom driveshafts with diffrent size ujoints at each end. with the Klune i have to lengthen and shorten driveshafts and i can use the same size joints at both ends.. what would you do?
For the transmission, you want to keep the 2.3 tranny guts and only swap the tail shaft. The ratios are different and you dont want 4.0 ratios with your 2.3.
sweet thanks for the info. they will swap out for shure?:D
