Tranny swap help!
BroncoKen
1987 Ford Bronc
Will a 1993 Ford Ranger auto Trans work in my 1987 Ford B2? I believe they are both A4LD.. Help if possible thanks :dunno:
don't quote me for sure, but i'm pretty sure that it will.. the internals are slightly different but the casing i think is the same
yea its only gunna cost me $200.. i have had so much transmission issues with this this this will make the 4th trans since i got it bout 5 years ago. i also considered rebuilding my current A4ld any opinions? i am mechanical inclined and have installed many transmissions but i have never been inside of 1..
Actually, I believe the casing is different too, but don't let that throw u. The one I pulled out of my 88 partd truck looked diff, but had the same plugins. the problem u will have is the shifter and kickdown linkage is different. No worries though.
The important question is "What engine is in each vehicle"
If they both have V6's the bellhousing bolt pattern will be the same.
I *think* the same is true of the 4 cylinder engines (common bolt pattern) but I don't know that for sure.
The newer A4LD will be at least partially computer controlled whereas your '87 BII does not have any computer control over the tranny at all.
Again, I don't know about this, but I'm thinking you're going to need the transmission, tranny computer, and any applicable wiring harnesses associated with the TCU.
Hopefully someone who knows more than I will set you on the straight path to ford enlightenment!
There was no stand-alone trans controller. It was an integrated function of the PCM. You may need to swap valve bodies.
Also, yeah, has to be out of a 2.9 or 4.0 truck for it to fit your B2.
