P93suafilo
- Mar 23, 2015
- Lehi UT
- 4.0 V6
Well I am in some very uncharted water and would really appreciate some help. I have a problem that I have run into with the good ole tan 89. I posted this to my build thread but thought I might get more people seeing this here.
Please forgive me if I use improper terms and if I do not describe enough then just ask and I will answer as best I can.*
So I have a 1350 transfercase doubled to another 1350. And I believe I have a M50d-R1 tranny. The problem that I am having only occurs when I am in 4wd lo/hi and when the doubler is lo/hi. But as I am moving forward it will feel as if it falls out of gear and then I will have no forward movement. Occasionally I will be able to reverse but then when I put it back into first there will be a clicking/winding/spinning sound as if it just doesn’ t want to go into gear. To fix this I have to shift the transfercase from 4wd to 2hi then back down and I will be good to go till it falls out again. Someone told me that it could be the syncros in the tranny but when I looked up those symptoms my tranny doesn’t have any of them. Any input would be great.*
