tranny mounts - same AT and MT?
jmfavrin
recently while trailing i went down a hill and got my tranny mount bent up so my u joint on my rear driveshaft is hitting another crossmember :/
worst part is that the only B2s and older rangers in the junkyards around me only have ATs in them and my b2 is standard.
My question is: is the tranny mount the same for an automatic and standard? or ill ask, what years can i look for that will bolt up?
bump. if you have done a tranny swap ether from auto to standard or the other way around, did you have to put in a different crossmember? im just asking for a yes or no here.. my truck is undrivable right now
Depends on the length- i did a auto to manual swap in 2wd- have installed 3 trans only two different crossmembers and two different mounts
