tranny in gear or out of gear on install?
BigIsland
just put the 5spd tranny in on my 94 4x4 4.0 and can't get the thing to shift. seems as though it's stuck in a gear but has play like its in neutral?. doesn't want to shift into any gear.
i believe i had it in gear on install to rotate the input shaft, was i suppose to keep it in neutral? or either ways fine?
haven't fully bleed the system yet, could that be a problem also?
Thanks for the help!.
Your shift lever is probably not installed correctly. That's a common error.
fixed the problem, used a screw driver to put it back into neutral. pops came by and had the magic touch, haha,
