Tranny help for 302
If that bronco has pretty much anything other than a stright 6, 302 or a 351W it won't match up.
Matt
That's a Toploader 3 speed and Dana 20 transfer case. Not sure if it's from a 79 Bronco though, but it was std equipment in the small broncos. Good strong stuff. You won't break it. The bellhousing is a 164 tooth and heavy as hell. I've been working on an older Bronco frame, thinking on building an ORV tube frame and am gonna use the same setup, but with the smaller 157 tooth aluminum bell and a McCleod hyd throwout bearing
he's right, not stock 79 bronco attire, that stuff will work though. I never noticed your like last night
Matt
