fireman947
- Sep 3, 2012
does anyone know if the guts from a tranny behind a four cylinder will work in the housing of a tranny from behind a 3.0 six cylinder???
Why? Sounds like you will be taking a step back by putting a weaker trans behind a larger motor.
Sent from the road while ignoring traffic
The internals are not weaker than what he has. He would be going with different ratios if anything. IIRC the 3.0 has the more desirable ratios of any of the M5OD-R1's...meaning a lower first gear ratio.
2wd 3.0 with a 5 speed manual...
If the OP had searched, he would have found the internals of the 2.3, 2.9 and the 3.0l M5OD-R1 are all the same. The 4.0l is the only one that is different, but will still fit in any of the other cases. (except the M5OD-R1HD case.)
90% correct.
All M5OD-R1 guts will fit in the HD case as well, but you have to use the HD ouput with the HD tailhousing since the seal location moved to accommodate for the VSS sensor. Or reuse a non VSS tail housing and output on the HD case.
-PlumCrazy
