tranny fluid
Sorry, I misunderstood your statement. No, your transmission is fine, just get the correct fluid in there soon.
my haynes and chiltans manuals state to use 80w gear oil in all mist and mazda trans between the years of 83 and 87 than all 88 and newer mist use 80w and mazda use mercon atf if thats helps any. my books cover 83 to 92 models. hope it helps
dang man im not agreeing
Well, tell you what. Leave it in there. And when your tranny melts down cause of the wrong fluid, post back to us with the carnage.
Your book also never mentions the D28/35 hybrid axle, or the fact that SOME LATE model 90 Bronco II's came with actual M5OD Transmissions does it?
The book is wrong. Simple as that. We're trying to tell you, but if you refuse to listen......:dntknw:
