tranny bellhousing torque specs
ray115
1997 4.0 v6 for
trying to figure out the torque specs on the bolts right behind the bellhousing which hold the bearings and shaft. 1997 ford ranger 4.0 v6 4ald tranny i believe
here is a pic of the bolts i want torque specs for
Wait, do you want specs for the torx bolts in the pump, or the bolts that hold the bell to the case?
No i know the bolts that hold the bellhousing on are 40 the bakck of the bellhousing that is around the bearing i am curious about
I believe there are 6 bolts
Geeze. You kids need to learn some patience.
First, you have a 5R55E, not an A4LD. A4LD was discontinued in 1994.
Now, for your torque specs. Tighten in a star pattern to 16-21 ft-lbs.
Thanks man appreciate it
Hey all just asking a question on torque specs for a manual transmission reinstall
