trail rig ??
built2bashranger
i have seen a few trail rigs (on t.v and in mags) with a small winch hooked to ther rear axle above the diff. i was wondering what this is used for???
tuckin the body down for a low center of gravity? ive kno wat ur talkin about but im not 100%
I usually see it hooked to the front axle. It's to keep the suspension from unloading (throwing all the vehicle's weight onto the rear) as you climb up a steep incline. This improves handling and stability.
thanks i saw it and was wondering why?? but all the above makes sence
all of the above and then some.
i thought thats what traction bars are for. i may be wrong.
Traction bars are for axle wrap which only leaf spring axles can suffer from.
Axle hop is when a truck is trying to climb a rock obstical (or concrete, or whateve') and it gains&looses traction rapidly and repeatedly. Lotsa rock crawling vids on youtube show this. This also shock loads driveline the same as axle wrap, but a traction bar can't help you if your ona crazy steep hill.
And ya, like the other guys said, there is all-sorts of reasons why this is done in the sport.
Axle wrap is generally what causes the axle hop. Yes, traction bars do help with this.
