Denisefwd93
- May 20, 2015
- South East PA
- 4.0 V6
- Total Lift
- stock, may get leveling springs in front "somday"
- Tire Size
- 235
Because it's an old truck I'm replacing stuff I'm replacing the TPS so I got this new one from Advance Auto, the part listed on the box is the proper part # put it on, start the engine and RPMs are screaming! Put the old one back on, rpms back to "normal"!
The box has the correct part # the bwd part number is not in the plastic but there is a sticker saying 232 107
There doesn't appear to be a wrong way to install one of these but this new part has to rotate slightly counterclockwise for the screws to line up and the inside that rests against the throttle body shaft is not quite the same as the original, so something's not right?
