- Jan 6, 2008
- Age
- 49
- Armagh, PA
- Automatic
I have some video also but need to use a hi-speed to upload that.
Here's the drivers side...it drops in from the top but requires the steering shaft be removed first. Also had to dent tube #2 to clear the spark plug...the plug was actually touching the header tube.
OK...for some reason this pic does not want to work. I'll try to get it figured out....in the meantime.....
Here's the passenger side...it had to go in from the bottom. It required clearancing the starter mount on the bellhousing. Also had the dent the header tube about 2" ahead of the collector. A min-starter also made things much easier.
