toyota lift springs?
jarfly
So my buddie is offering me his pro comp lift springs for takeing his truck back down to stock height There 3-5" lift springs would these work on my ranger?
I believe NMB2 is running toyota pickup lift rear springs in his B2 buggy.
keep in mind that Toyota springs are 60mm which is 2 3/8" instead of your 2 1/2"
the pins are 3" off of center.
also they take either a 14mm, or a massive 18mm eye bolt.
and you can't just change out the bushing to a ford bushing because the ford bushing is 1 1/2", and the Toyota bushing is 30mm
and they are shorter than your springs by about 8"
um, sure wish he was closer were I could be like come one lets do it but i'd have around 4 hrs of driving to do this. may just pick up a set of chevys and go that rout.
kind of got to thinking about this, I want to bob my truck a bit. Would the springs being shorter help me? I want to go pretty deep in the bob, say tailgate around 7" from the wheel wells. Thank you advance
any more insight on this? These are a 4" spring, Would these give my ranger 4" or less?
