toyo kogyo transmission transfer case?
Dustinicus
i have a 2wd only toyo kogyo transmission and I was just wondering if there is a transfer case that would bolt onto it, or will i need a new transmission? The transmission as it sits works just fine now, and would like to keep it if possible.
thanks
Dustin
Shouldn't the transfer case you need be the same as everyone else? 1350/1354?
^^^^The OP has a 2wd transmission. He needs a divorced Transfer case or a different transmission.
I have read about people changing mainshafts? and using the tailhousing from a 4wd transmission but it's probably easier to find a 4wd trans and swap it in.
Richard
