is your hay wagon a semi trailer or a full trailer. full trailer meaning the tongue is attached to a steerable axle so the only tongue weight is the tongue itself. Semi trailer means no front axle so it has tongue weight (what we think of when we hear trailer)
but no your 7.5 would not stand up to it. the 7.5 won't stand up to the V8. 8.8 would be iffy with that much rolling weight, 9" would be better but then you have the problem of not enough brakes and I don't recommend doing it but if you must then I wouldn't go any faster than 15 0r 20 mph and stay in a low gear. if it is a semi trailer then absolutely no way
I wouldn't even consider towing an 8000lb trailer with my F250 unless it had electric brakes on it at the very LEAST. Trying to stop an 8000lb trailer with a Ford Ranger can only be done if you aim for the nearest tree and bail out before impact. Earlier this summer I had to use my 4.0 Ranger to pull a 3000lb trailer across a field so that we could use the winch mounted to it to pull my friend out of the mud and onto the trailer and just initially getting the thing to move without stalling required me to put it in 4low. Just trying to stop it while doing 15mph took some effort.
he didn't ask if it was a good idea, he asked if it could be done.
if u knew me in real life ud know it doesnt matter to me if its a good idea
