- Nov 30, 2001
- Gnaw Bone, Indiana
More power is always better. Just adjust the gearing to use it. And of course it needs the cooling upgraded to stand the new duty cycle. You can have a 200hp 2.3 on the stock cooling system and it works because you rarely use the power. But if you use it for any length of time, you need to make sure you can deal with the heat. There are lots of old motors that were used in pickups and in medium duty trucks, the 300-6 for instance. but in the medium duty truck the engine is installed with a radiator the size of a barn door and maybe even an oil cooler--and a 200# flywheel so it doesn't stall when you let the clutch out on a 20,000# load, and 6.17-1 gears in the axle. And you don't expect to go more than 45mph. Anything can tow if it has the support staff.
