towing a boat
pops13
I have a 97 2.3 5 speed that I bought last fall, have not tried to tow my 14 foot alum. boat yet, it is no more than 1000 pounds. is this guy up to the task? I have not towed with a 5 speed b4, I am a little nervous about this. can I tow it on the freeway? most of the time it will be local though.
I tow with my 2wd 2.3 5spd all the time... sometimes heavier loads.
14ft aluminum boat should be a good match for a little ranger. Just make sure you have appropriate tongue weight and you should be good to go.
I'm not a fan of bumper towing, but even if you don't have a hitch, you should be able to pull that no issues :)
I have a hitch on it, will give it a try hopefully next weekend, thanks.
It'll do just fine - you're not anywhere near a towing limit.
Tongue weight on my '94 Ranger is 200 lbs. My 15' Smokercraft Alaskan tongue weight is approx. 120 lbs. You should be OK. But it wouldn't hurt to invest in a nice receiver hitch. They use 3 bolts per side of the frame, and connect 18" back.
Holes are pre-drilled at the factory. Just my 12 cents worth (2 cents adjusted for inflation).
depends how well your engine runs
My 96 ranger will only do 135km/hr top speed, when I tried towing my 14 foot aluminum boat my top speed shrunk to 105km/hr. It didn't stand a chance in OD.
I did all the tune-ups, passed emissions, codes clear, I'm guessing maybe just bad carbon build-up, only get 18-20mpgs.
I doubt your 14 aluminum boat weighs 1000lbs unless its the super full size kind with wood floors and a big heavy 4 stroke outbourd.
I own a 14' Misty river with 25 hp 2 stroke. The boat by itself only feels like 200-250lbs. Outboard 104lbs, and trailer maybe 300lbs.
I tow my 16ft fiberglass switzer all over the place... and that things solid.... boat / trailer easily around 2,500lbs... No issues with the 2.3 5spd. I do have 4.10s, but also turning 31's.
the book says the boat weighs 300, the trailer is 300 to 350, motor is 95# and gear is maybe 100# with a full tank of gas, plus 100# of weight in the front to keep the bow down, looks like 900#.
You can tow 900# behind a bicycle--there's a guy in Sweden that has no car and tows his boat with his bike. It's a sailboat he cruises in with his wife.
well took the boat out twice, the truck pulls it with ease, even pulls up the ramp no problem.
no OD with load ... you should have no prob if you take your time towing it i just got back from hauling/towing 700-800lbs thats including my boat/motor all camping essentials
I can make it to about 125kmhr
I can make it to about 125km/hr towing my 14 aluminum(25hp) It just takes a half hour of full throttle to get there, I think It can even handle 100km/hr if I really want but usually go around 94km/hr to make it easier on the engine. Od is impossible but I'm assuming that may also be linked to the fact that I have the 3:45 gear. In my manual it says I'm not even supposed to tow anything but my truck gets the job done.
re
got a bigger heavier boat, 2500 lbs. to heavy for 4 banger stick, so I bought a 01 3.0 auto, handles it good with a new hitch, the truck probably would have pulled it but not up the launch ramp.
