Total Weight
PlumCrazy
OTOTM Winner
Solid Axle Swap
RBV's on Boost
2014 Truck of The Year
Millersport, OH
Does anyone know what the total weight of a 94' four cylinder 2wd long bed Ranger is? Just trying to get an idea
should be around 3200lbs
my short bed standard cab 4x4 is 3650lb with me in it, was 3200 with me in it when it was 2 wheel drive...
opeen the drivers door and look.
that only tells you gross weight...hes looking for net.
i think maybe your scales need to be calibrated. my '93, standard cab, v-6, 4x4 (no power options) is only about 3200lbs with me in it.
a base model 2wd 4 banger will be closer to 2900lbs.
My '90 4x4 single cab long bed weighed 2700 with no motor, 2900 for a 4banger 2wd sounds about right
