torsion crank ?
craveman85
new york
im going to crank my t bars a bit but was wondering if its necessary to get cam/bolt kit to do so. ill probably lift 2 inches. its actually 2wd at the moment but im collecting parts so i dont need to worry about cv shafts.
so theres enough adjustment in the stock bolts then? what kind of lift would i need to do to require the cam bolts then?
i just did this to a 4x4 and had to get new bolts....rasied it about 2in....the stock ones looked to be preset and not adj. when i removed them. idk if its the same with 2wd but i would assume so. look an see if the bolt on there now has to round washers on both ends. if they do then you can move them and your not gonna need the kit. other wise you need to spend 50 bucks on two set
I was thinking about cranking up my torsion bars all the way up and adding a 3" body lift but if I do the 3" all the way around and crank the T-Bars then would the front be higher than the rear? and if so what do I need to , to the rear to make it level to the front? also if I did that what size tire would you recommend? sorry for all the questions thank you for any input
