TOO much positive camber 87 BII
groovtubin
NC
2.9 V6
Anyone have advice on how to remedy? Ive seen one utube video @ a adj nut on bottom ball joint, anyone ever done this? Pax side is way worse than driver, Thanks in advance!
Adjusting that changes the toe as well, I could go into detail but don't have much time right now, it's basically loosening the top pinch bolt and pulling the top nut or snap ring or whatever (been a while since I've looked at a D28) then lifting the adjuster and moving it over a notch or two.
I would first look at the toe setting, if it's towed in it will go that way too...
Thank you so much for info n your time! God bless !
Thank you so much! Sporeciate your time. God bless!
