- Nov 12, 2018
- Maryville
- State - Country
- TN - USA
- Drive
- 4WD
- 2.8L
- Automatic
Well actually it was Monday on the way to work.
Quick summary. I was driving to work like I have for the past 5 years with the BII. Went to take off from a stop light and the engine stalled. Tried to crank and restart and got nothing, I could have flooded it trying to get it to run, but I killed the battery trying to get it going.
I Fred Flintstoned it out of the busiest highway in town to the intersection with a median to get out of traffic. Called the wife and asked her to bring me my jump pack.
Got the jump pack on it and got the Bronco fired up and headed the mile to work. As I was pulling into the work parking lot and turning into a spot, died again.
Battery was weak and was 7 years old, so I decided to go to lunch with a buddy and pick up a replacement. New battery did not get the Bronco to start.
I could tell I wasn't getting any spark. So I tired swapping a new HEI module and a new coil just as a hail mary to try and get it out of the parking lot. Neither fixed it.
Threw in the towel and got it towed home today from my work parking lot.
Did some initial testing tonight and confirmed with Key On I've got 12V to the hot side of the ignition coil. I hooked up my timing light and turned the engine over, I never got a flash, so I don't believe any cylinder is getting spark.
So, just a refresher, I've got a Duraspark Distributor with a GM HEI module and I'm running the stock TFI coil.
Guess I need to read up on how to test a HEI module, but I tried a new one as well and no dice.
I'm suspecting the distributor at this point. Any tips on how to test it? I did confirm the rotor is turning when cranking the engine. The contacts have some carbon on them, but nothing crazy. The cap and button has been replaced in the last couple of years.
