Todays weather
It's been between 44 and 48 for the last week here due to the fog blocking the sun. It is currently 46 and foggy. The fog might break later today as some weather moving in is going to make the atmosphere slightly less stable later today. Some weather models indicate the fog will continue to clear out. Others are showing the fog coming back overnight. Since there is such a strong inversion, I think it will hang around probably through Tuesday night, then clear out as stronger downslope winds come off the mountains with much lower dewpoints, effectively moving drier air in and significantly weakening the inversion. So, instead of 45 degree lows and 48 degree highs, the sun will be able to warm the afternoons up to the mid-50s and the clear nights will drop down to around 40 after the middle of the week.
The low was a wet, drizzly, foggy 36. The high was a chilly and overcast 44.
Cold* and rainy. Same as it has been all week. Started last Sunday, let up on wednesday, resumed on Thursday.
*Anything below 50 is cold in this part of GA. I like it, but not when its also wet.
My thermometer indicated a low of 42 and a high of 42. At a local airport, the low was 42 and the high was 44.
it is colder than a witches tit in a brass bra... -1 with a windchill of -16 this morning. supposed to get to a near tropical high of 9 degrees this afternoon.
AJ
9 degrees here when I went out to scrape the driveway off. And leave a path of tire tracks out back so the small dog can get out when needed.
We got dumped on with snow. Yesterday morning they were saying 3-4 inches starting at 3pm and all the snow would be done by 1am Sunday…
Well, it started around 3pm yesterday and by this morning there was about 6” on everything we didn’t clear last night. Started shoveling and it started snowing again, dumped another 2-3” on us this morning. Also a balmy 15* out now. I’m really unhappy that my shop isn’t extended and I don’t have a solid 4x4 or AWD to drive right now.
cold day, warm cookies are on the way!
Event Coverage
TRS Merch
