Yeah, that doesn’t even scratch the surface of what all I have backlogged to do, that’s just what I had considered reasonable to get done before now. Two concussions within 5 days changed that. Things went from making progress to on hold. Now I’m starting to finally gain a little bit of usefulness, enough that I could try to start doing a little here and there and the weather is too cold and miserable. I need a garage. Maybe this year I can make that happen. I figure if I can get a garage, two stall with heat and electric and a lift I should be able to cut my repair times in about half, which would be a huge benefit. Maybe even less than that. Right now I waste a considerable amount of time dragging stuff out and packing it away and having stuff scattered too many places to be efficient, plus I’m at the mercy of the weather.
The F-150 and dump both need some bodywork. Ranger needs a little love, the green one that is. The blue one needs a front clip and frame straightened. 97 Explorer needs a fuel pump and engine bay and front clip back together. Box truck needs the cabinets finished in it and the cab ripped off and turned into a trailer. Shed needs finished. Couple little woodworking projects on the list. Let’s not even talk about all the work on my property and projects around my parents.
And my desktop computer needs a new power supply. That it’s needed for over a year now and should be here Friday.
