tire sizes? on a 2003 fx4 cranked 2"
dch1992
lake havasu city az
wondering if i can squeeze 33s under my 2003 ranger with 2" cranked bars on 15" Alcoa right now im running 31 10.50 on it and its fine but i want BIGGER and i heard you can run 33 but not sure?
you can run 33s but they should be 10.50 wide rather than 12.50. those 7" wide rims are too narrow for the 12.50.
good to go on 33x10.50. Some have ran 33x12.50 on aftermarket wheels with maxed bars.
My mom works at Alcoa! Way to go, let her keep her job of 30 years! :P
If you want to go cheap, do a BL and un-crank your bars. It's worth it. Some may disagree because they don't like body lifts, but I'm pretty happy with mine. And you’re just going to wined up replacing CV's and ruining your wheeling trips. Unless of course you want to carry spare CV's and don't mind the work. But I fit 33's fine with em cranked before I did the BL.
biggest id go is 33 x 11.50 :icon_thumby:
my 32 x 11.50 rub on the inner fender skirts above the upper
a arm!:annoyed:
btw ive go the same setup you do! and thats without the bars uncranked!
good luck on finding a set of 33x11.50
i did run 33x12.50 for about 2 years.i didnt have any problems but i was also runnin a set of 15x8 eagle alloys with 3.25 backspacing rather than 3.75 (which is standard on most 15x8). it made a big difference.
without a lift? and yea i have only seen that size once or twice. either that or i was dreaming..:annoyed:
yup, without a lift. i also ran 35s without a lift but had fiberglass fenders and no rubbing on the front but little rubbing on the rear.
what lift do i have now? i did a SAS with coilovers and a dana 44 out of a Rubicon back in december. i have skyjacker springs in the rear.
i have too much pride to buy a lift kit.
thats right i remember reading up on ur truck.. damn i wanna get rid of my ifs t bar setup and do a sas..
