tire size difference?
farmer
Rochester, NH
Mix of 78-96
13ish
39.5x15.5
i just bought a set of BFG A/ts 4 are 31-10.5s and one is a 30-9.5 and one of the 31s is pretty bald, is running a 30 on the front going to mess anything up? is it going to look dumb as hell? or should i run the bald 31 until i find another decent 31?
You won't want to use the 4wd with a smaller tire in the mix.
ok that makes sense
It will pull to the side with the smaller tire but as long as you don't put it in 4wd it won't hurt anything. You could counter that somewhat by putting more air in the 30 than the 31.
i figured either do that, or screw it, put the bald one on the back, I've seen worse....lol
