Tire options
Nathan123
Millersburg Pennsylvania
My 89' bronco ii's stock tire size is 205/75/r15, the diameter is about 27". Will 235's fit (29" diameter) without rubbing, without any modification? Will the 2.9 and A4LD be able to push 235's at highway speed ?
I put 30x9.5 on my stock 87 it hasn't rubbed yet.The other part realy depends on the gears you have but its not that big of a change to make a big differance.
As long as the motor and trans are in good shape and you have 3.73 gears or 4.10 gears, you should be happy. I've heard that it's not too bad on 3.56 gears, but I don't think I'd want to run it like that.
im a fan of 31's on my b2 i can fit them without moving lol...they come really close to touching the front fender in the back when turning. go over a bump not happening
