Timing wont set??
B2Mann
Arizona
Was checking the timing on my 90 B2 and I noticed that the line that I have marked on the 10btdc is jumping around. I can take the spout connector out and itll sit at 10. If I plug it in, itll go up a few degrees and then start jumping sporadically. unplug and it sets at 10. It does affect how well the engine runs unfortunatly. Any thoughts as to what this could be??:icon_confused:
You shouldn't even look at it with the spout connected.
Why? because the computer varies it and you can't do a damned thing about it.
Set it with the spout removed put your light away and then plug the spout in and forget it.
AD
Thought maybe it was an issue that would need to be assessed. But obviosly it isnt. thnx
