timing question
junkfixr
Virginia
I set my base timing (spout out) around 10 degrees BTDC and drove the truck for a few weeks. Typical, sluggish 2.9 engine but runs super smooth.
I can advance the timing just slightly a couple of degrees and it's very light on it's feet. Plenty of get up and go, smooth throughout the entire pedal, but... it has a slight "pop" accasionally at idle, and sometimes a little sputter under a load at high idle. No spark knock or pinging.
Am I hurting anything ? Mileage ? It seems to have no happy medium. Either I live with a slight pop while idling, or set the timing to where it idles smoothly and live with a sluggish truck. Any suggestions ? Thoughts ? The engine has just under 160,000 miles now.
Thanks in advance,
Kevin
runs good
at 12 degrees BTDC, but just has a slight miss/shimmy at idle. I've got the feeling I'm just slightly too high in time to get a good idle. Considering the mileage, would you suspect a valve deposit? Is it possible I'm just a little too advanced in time to get a smooth idle?
I'm gonna try a little higher (89) octane and put some 44 heat range plugs in place of the 42's. May not make any difference, but it's a cheap experiment. Anyone else have an experience like this ?
