J.Incognito
So I was driving my '85 ranger and hit a bump when my ranger just shuddered to a stop. It would start at first but soon it quit completely. So I got a brand new battery, fuel pump, distributor cap, starter, spark plugs, plug wires, fuel sending unit, fuel filter, and the carb says it was remanned 1 1/2 years ago. So when it started giving my problems I replaced all this. I was able to get it to start but wasn't getting compression in cylinder 4.i just changed the head gasket and now I am able to start it. But after running rough for a little bit it will die and gas will spray out of the top of the carb. I keep doing my timing over and over again but everything I set the cam and the timing pulls on TDC and crank it twice it will never be back lined up. It always seems to be a few teeth off. However it runs well for a while then gas out of the carburetor again. What is my real issue here and how do I fix it. I can't seem to get the camshaft timing right or something. Help!
