- Jun 13, 2016
- Connecticut
- 2.9 V6
- Total Lift
- 6
Hi guys, I have a 89 Bronco 2 with the 2.9l. I recently pulled the engine and did a full overhaul, and sadly I did not take a picture of the cam and crank sprocket before I took the chain off. So fast forward to now, the engine is in the truck and i got it to run with an initial timing of 10degrees. The truck runs like junk and I’ve done everything from making sure the dizzy is at TDC-pulling the intake off and checking fuel injectors. I’m about to pull the timing cover off the truck and make sure my cam and crank are aligned BUT neither of my Haynes manuals have a diagram of where the sprockets should be. I’ve been coming home from college to try to get this thing finished but I’m at my literal wits end here..any advice or guidance would be greatly appreciated. Side note- when I installed the timing chain I lined the small dots up on both sprockets, but I know the cam has marks for advance and retard and my research into which is which has gone nowhere
-Jon
-Jon
