timing belt - 94 Ranger
johnnybronco
Austin, TX
I just volunteered to replace my friend's busted timing belt. I have a Bronco2 with a chain, so the Ranger is a little new to me. On the 94 Ranger camshaft sprocket there is a painted-on mark on one of the teeth and another painted-on mark on the inner timing belt cover. I assumed these were the marks to line up, I didn't see any of the diamond shapes or triangle shaped marks that are mentioned in the Haynes manual, but I didn't look to hard either. Once we buttoned her up she barely started - obviously the timing is off. Anyone ever done the '94 and can tell me what I've done wrong?
There are diamond marks. You just need to look at the pulley and back timing cover really.....really good.
Here's what mine looks like. I'm not seeing any triangles like in the other photos in this forum. Am I looking at the wrong thing or is mine just different?
Timing Mark Alignment . may be realignement faillure
engine size ???........ I help you
I'm about to do on mine
.....you have Rotate engine at vibration dampener bolt until compression (pressure) is felt.
Align Timing Marks
my engine is 2.3
I saw another thread where the guy had the same marks on his, so I think I'm lined up OK. My friend says there were other problems before the belt broke, so we are looking for other problems now.
