donlightbody
The head swap went fine, when the pistons were exposed I turned the crank to clean the carbon off the top of each and for some reason thinking as long as I returned the crank back to #1 TDC the distributor gear on the cam would be back in the correct spot. after putting it all back together is fired up, ran kinda crappy and would die after a few minutes of idleing (to run motor flush through the oil) and when I took it out on the road she toppped out at 45. Got to talking with my Dad and we got to thinking about the 1 turn of the crank. Did I set the timing off 180 deg? I tried setting it back another 180 and won't run at all. Then back to (what I think is off by) 180 and runs like crap. There have never been any ignition issues before this. Ideas? possible the chain jumped a tooth?
