- Oct 5, 2016
- Saskatchewan, Canada
- 2.9 V6
- Automatic
OK, I took it for a ride thru the neighborhood and to get some gas. It's definitely not right, it literally feels "sticky". It will come back from a hard left or right but will not center. It's not free enough to do that.
What's odd is that loosening the four bolts does not to resolve the binding. And, if I turn the wheel in small amounts, the plastic shroud that surrounds the tilt mechanism also moves. I have no idea how to remove that shroud so I can't see the tilt mechanism to determine if that's the issue.
How does it move? does it move as though the steering column is bumping it from inside? We might have found the problem. Something (unknown, mysterious!) happened to the tilt joint. You might be able to test by tilting the wheel so that the column is perfectly straight. At that point, is the steering still abnormally stiff?
