Tightening lower ball joint nut...I can't!
The_Dealer
Macon, GA
Hey guys I loosened my lower ball joint nuts when I did my camber bushings. Now I can't get them tight. I can't get my wrench in there to tighten it. Any ideas? Also the stud wants to turn. I loosened it with a cresent wrench but now I can't get it in there. I've tried everything? Is there a special too or something? I could get it tight if I could easily get the shaft out. What yall think?
Take and hit the bottom of the BJ with a BFH, then put a jack under the BJ and lift the truck up off the jackstands, then tighten. Turn the wheel to lock to aid in access to the nut...
SVT
I tried that, but I just can't seem to get enough clearance to turn my wrench. Even with the wheel turned and the shaft turned just right. Cresent wrench won't work and I don't know what size it is for a wrench, I don't have the right size. Was thinking if I pulled the shaft I could get a socket on it. Alignment shop tried what he called w crows foot and he couldn't get enough clearance to tighten it eit
IIRC the castle nut size it like 13/16or 15/16, but I had to tighten the top BJ to specs then the bottom would stay still and let you tighten it.
I will go outside in a few and check that size for you. I cant remember if i had to buy a new socket,That was a size 24 and i only have used it once
Sweet thanks. I think 13/16 was the only one I didn't have. Long story don't lend tools lol. That thing is a pita to get to.alignment shop couldn't even get anything in there to tighten it. I can't get the boxed end in ther and I think he used the open end. He seemed kinda retarded so I dunno how hard he tried. He prolly tried it with the tire on and it off the ground. I got the pass side tight but can't get in there on the drivers. Even tried some vice grips
You will need to pull the axle shaft out (under the impression you already had it out), then use a closed end wrench to tighten it....
SVT
I've never tried to either loosen or tighten the lower balljoint nut on a TTB front axle witout haiving the rotor, spindle and shaft removed.
Getting a wrench on it is childs play with the spindle removed.
Part of your trouble was that you weren't supposed to loosen the lower while doing a camber bushing.
AD
Dang I coulda swore I read to loosen the lower bj. And the saft isn't out, but ill pull it, repack my bearings, and tighten the lbj's...thanks guys!
If the camber bushings are well smeared with waterproof marine grade grease you loosen the pinch bolt and they move around rather easily.
My sleeves turn freely even after four well salted pennsylvania winters.
I took them apart while replacing a wheelbearing and an outer U-joint just last week...
I am very reluctant to disturb the lower balljoints unless I'm replacing them, part of that is the issue you are having
the other part of it is I don't like un-necissarily wasting my stainless steel cotter pins:)
AD
