magnetnerd
Hey,
This might be an incredibly dense question, but here goes anyway:
One of my tie rod end boots has ruptured, but I don't think the inner/outer tie rods actually need replacing.
1. How do I know if my tie rods need to be replaced? And, are the inner and outer tie rods typically replaced at the same time, or would it be acceptable to replace just the outer tie rods?
2. I'm looking at these (http://www.energysuspensionparts.com/proddetail.asp?prod=9.13101) instead of replacing the tie rods. Thoughts? It almost seems too good to be true that a $4 part can keep me from having to spend a couple hundred on tie rods.
3. The boot under my pitman arm is also ruptured; instead of replacing the pitman arm (some come with a boot and some without), could I get a universal poly boot from energy that would serve the same purpose?
Hopefully that wasn't too dumb.
